FS: HID Conversion, $79: Top quality, LIFETIME warranty!
In most cases, it is a matter of personal preference whether or not you install a relay harness with your kit, however, we do recommend it for use on all vehicles. On most vehicles, there will be no problem using the stock wiring, but if you want to be 100% safe, a relay harness is reccomended.
Here a You Tube video with more information: [ame="http://www.youtube.com/watch?v=tDvwR8-9DcY"]What is an HID Relay? Do you need one? from Diode Dynamics - YouTube[/ame]
-Michelle
Do you guys sell just the H11b HID bulbs in 5000K? I just ordered an HID kit from somewhere else and the H11 bulbs have a base that is too thick, so I'm hoping just to buy the correct bulbs from somewhere else. If you do sell them, what type of a connection do they come with, just two wires or something else?
This Precision HID conversion kit contains everything you need to convert your factory halogen low beams into HID, High Intensity Discharge.
Then why only advertise illegal HID kits? Factory halogens are not HID compatible. How much for E55 lenses and shrouds?
We do not carry lenses or shrouds.
So in other words you're false advertising and only selling something that can make cars mobile road hazards? You said you sell complete conversion kits. A conversion kit (retrofit) mostly revolves around replacing the incompatible halogen optics with correct HID ones. This is a REAL setup that will convert stock halogens to HIDs: theretrofitsource.com/product_info.php?products_id=141
You can't simply throw some random kit on a car. It's dangerous and illegal.
Our H11b kits have a metal base which has a better tolerance to fit the H11b properly. They have standard connectors, if you'd just like to get the bulbs. Thanks!
does any knows where to install at CA area ? if so, how much would it be for installation ??:confused:
