Ron
09 V-6 with premium
Sat. wife calls and says car will not rev up. Made it home with car at a fast idile. Said there is a light on the dash lit up. I came home and she had the book out and it was the emissions/check engine light but the ESC light also came on immediately after the check engine light. RPM dropped to fast idle and stayed there. For the check engine light Owners manual says that the car should operate but take it to dealer and check it out. No mention what to do if ESC also comes on. I went out and started the car drove it and it ran normally. Used it in the afternoon no warning lights of any kind. Sat. evening on way home from church same thing. Stopped shut off restart and run normally. Called nearest dealer (2-1/2 hrs. away) on Mon. and was able to get in on Tues morning at 9:00 AM. Coded P2106 Limp Home Mode and P0638 Throttle Actuator. The TP (throttle position) sensor tested bad. Replaced it and problem thus far has been solved. If this happens to any of you it may help a little.
McKie Hyundai in Rapid City Sd. Very good experience with their service dept.
