jasonsw
- Jan 12, 2009
My car won't stop even if I step on the brake 'pedal to the metal' all the way down...
I told this to my Service Advisor back in Dec 2012 and again on May 2013. In Dec 2012, techs weren't able to 'duplicate' the issue.
In May 2013, Service Advisor found factory 'campaign' (recall?) and replaced the brake fluid. It seemed fine for awhile but it's acting up again.
For example, I am at complete stop when I wait to make a left turn as the light turns Yellow at the intersection. I try to turn quickly (accelerate) and sometimes it trips the ESC (Electronic Stability Control) and the car won't stop at next stop.
In another instance, I turn right SHARPLY and ACCELERATE FAST to go onto the Freeway ramp to merge onto the Freeway. As I was getting off the freeway after traveling 10 mins to my Hyundai dealer, the car won't stop. Yes, 10 mins. When this happens, I first try to stop the car, then I shift into Parking and shift back Drive again then the brake pads seem to pop up and starts to work again...
I took it again to the dealer service center and this time, they were able to 'duplicate' the braking issue and it was concluded that "The vehicle is not safe to drive"
This time they found the problem to be Internal ABS Brake Module Fault and it will charge me $2,230 + $291 (front brake pads).
Service Advisor said, "Sorry but this warranty ran out at 60,000 miles and you now have 65,000 miles."
Unbelievable. I brought this issue up at least 2 times since Dec 2012 and this is what I am told?
Even when they performed this "factory campaign" (recall) I had 60.440 miles.
I fear for my safety and public's safety. I want your input. I am thinking of contacting Hyundai America to see what can be done...
BTW, I find it interesting that it would give me a Multi-Point Inspection Report with Green section circled that I have more than 6mm Brake Pads (remaining?) as recently as 10 weeks ago. Now suddenly I need to replace my front brake pads?
