Can I disable one of my key fobs?
stevebxl
Jacksonville, FL
2013 Genesis sedan.
Sometime my wife leaves her purse in the trunk with her key fob in it when we walk, etc.
Is there a way to disable one key fob so someone can't get in the locked car while we're gone yet still have mine working?
Take out the battery or place in a lead lined case.
My wife and I just take both fobs with us when she leaves her purse in the car.
Once your wife's purse w/ key fob is in trunk you can disable the auto trunk open by way of the trunk disengage button located in the glove compartment .
Once you return to the car you will need to reverse the process to unlock and open trunk.
Of course you can also open trunk with metal key removed from fob.
If you leave the key in the trunk the doors will not lock and anyone can get in it a and drive away.
Doors lock and stay locked on my 2010 tech pkg Gen.
One would absolutely need to test on their own Gen to be sure the doors are locked.
Please be sure it works for your car. I would not want anyone to leave their car unsecured as a result of my advice without first
Confirming it works for you.
When testing make sure 2nd key fob is far enough away from car to not be recognized.
But But But if the Key is in the trunk you can still open the doors and start the car and steal the whole car including the purse.
On my 2009 if a fob is in the trunk I'll get a long BEEEEEEEP warning if I close the trunk lid while the engine is off. The "key in car" detectors clearly can see into the trunk on my car. I tested this a long time ago, one fob in my pocket, the other in my briefcase in the trunk... I carried both at the time in case one died or got lost since I'd be stranded (nobody at home to call and say "bring me the other fob"). After work one day I tried to lock the briefcase in the trunk while I went to dinner and the car warned me that I was leaving the fob behind. Had to pocket both of them to get the car to be quiet and lock the doors.
mike c.
mike c.
I get the warning also from my 2010 Gen. The audible warning doesn't prevent disabling the auto trunk feature. It's just a warning to let you know a key is inside vehicle. The audible warning only last a few secs on my car. I can also lock all doors with a fob left in trunk by using the door lock button which is on other fob that is usually in my pocket. Of course the trunk will only be locked if the trunk lock switch is disengaged . That switch is located in the glove compartment. If I recall correctly this process only works using the fob door lock button and not the button located on the vehicle door handle. Fortunately the door handle button doesn't work which could lead to lots of folks locking their keys in the car accidentally.
I would appreciate someone else testing this process and confirming if it work on their Genesis .
Thanks
I believe the other thing you can do is to manually lock the car door with the actual key that is in your fob.
Thanks
Basically what my 2009 does. I just tested it:
a) tossed a fob in the trunk, closed the trunk. Got a long and loud BEEP as I expected.
b) once the beep finished, I tried to lock the doors with the door handle push button: the doors did NOT lock, verifying the theory the car tries to help you not lock the key fob in the car accidentally.
c) tried locking with the second key fob: locked normally and remained locked. This surprised me.
d) I then put the second key fob on the other end of the house so the car couldn't detect it. I tried to unlock the doors with the door push button: nope, stayed locked even with a fob in the trunk.
e) tried to open the trunk: it opened and the car flashed the amber lamps to let me know the alarm was temporarily dis-ARMing... the alarm detected the fob in the trunk and didn't realize it was inside the car instead of in my pocket. When I closed the trunk the lights blinked again to signal alarm ARMed again.
So, to lock a fob in the trunk, one has to remember to use the glove box push button to disable electrical controls of the trunk first, then lock the car with the other fob. And hopefully nobody notices the long BEEP telling the world "there is a key fob somewhere in this car... break in and find it, drive away." If you skip setting the glove box switch then the trunk is effectively unlocked and anybody can easily get into it.
mike c.
mike c.
Exactly what I experience with my 2010 tech.
Mike, Thanks for confirming and explaining the process much better than I did.
2013 Genesis sedan.
Try wrapping the key in aluminum foil. I've tested other transponder systems and wrapping the key blocks the signal.
2013 Genesis sedan.
You can always get a new wife :)
Try wrapping the wife in aluminum foil. Worked for Jane Fonda in Barbarella.
Your wife has no pockets, but you do?
