How to change Display
warreneaux4
Houston, Tx
I think I have read through the Owners Manual but have not found a way to change the brightness of the monitor showing temp, time etc.
During the day it is very difficult to see due to being so bright.
Is there a way to do so?
Thanks
Earl
Select Home - Settings - Display. All display adjustments are available there. PS: This applies to the Ultimate version - not sure about the others but they're probably similar. Good luck.
Being the '09-'14 forum, there isn't an "Ultimate".
Earl, what trim level do you have? In the Tech, the clock and temp are in two different areas.
Oops! Sorry.
If it is a non tech the only way to do it is to dim all display lights, the dial on the left of the steering wheel.
Sorry, I should have mentioned that it is the Base Trim.
I have fiddled with the wheel on the left of the steering wheel and it doesn't help in the day light bright sun.
Thanks to all who responded, I really appreciate it.
Earl
