Thank you for the links... I have already looked at many of those posts... the problem is, I don't know which lighting upgrade goes with which part from the website, (except the trunk and license plate, those are easy to recognize). So, I thought to narrow it down I would make a list. Also, some of the members buy their lighting from pepboys, or custom create it. (i.e. the glove compartment) Bottom line... I don't know enough about it to completely understand the other threads and I was hoping someone would explain which are the most effect upgrades and from my list, I would know which part to buy.
Ahhhhh... Sorry... now I understand. Let's try this----
Genesis LED DOME Panels - NO, These appear to be the same as the ones already stock in the Genny.
Genesis LED Floor Module Set - This would be a good one, but I felt it might be TOO bright, so I used the PepBoys Pilot module here. VERY easy fit.
Genesis LED License Plate Module - YES - This is the first change I made with the KAI modules. They are VERY VERY bright and the color looks great on my Platinum Genny.
Genesis LED Fog Lights -Haven't done this one. A bit pricey for the little amount I use fog lamps.
Genesis LED MAP Panels- No - These appear to be exact replacements for the OEM.
Genesis LED Trunk Module - YES - This was the second mod I did and I LOVE the fact that the trunk looks like daylight at night.
LED Mirror Signal Lights -NO- Might be interesting to do some time, but I feel it is redundant... The Signal Repeaters on the front side of the mirrors do verry well since the wrap to the sides and can also be seen from behine the Genny.
Genesis OEM LED Signal Rep-NO- These again are the OEM parts. No change if you order them.
LED Side Mirror Ground Lights - No- I beefed up the under door lights with the PepBoys Pilot modules the flood the ground with light. The Mirror Ground Lights are also called 'puddle lights'. They MAY help if you wind down the window and look out, but by the time you open the door, that light is lighting the ground where you won't be stepping! And, it appears to be a not so good mounting method.
Now... having said all that- I like the KAI guys a lot. They have given me spectacular customer service.
I may have not answered all you're looking for. Feel free to ask more or send me a private message and I'm happy to give you my number if it's easier to talk.
