Aftermarket Lighting
klg
Pasadena, CA
Below is a list of different aftermarket lighting I found on Hyundai parts website. Has anyone installed any of these and if so, how do you like the lighting? I'm not sure what I should start with and if it makes a big difference. Any help, or suggestion will be appreciated. Thank you in advance.
Genesis LED DOME Panels
Genesis LED Floor Module Set
Genesis LED License Plate Module
Genesis LED Fog Lights
Genesis LED MAP Panels
Genesis LED Trunk Module
LED Mirror Signal Lights
Genesis OEM LED Signal Rep
LED Side Mirror Ground Lights
KLG- there are many threads here that show the results of adding the KAI LED panels and others. GS300rich and I have posted many pictures and helpful hints. You might try the search and look for LED Lighting.
Here's a couple of them to get you started-
http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=1104&highlight=lighting
http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=1673&highlight=lighting
http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=995&highlight=lighting
Thank you for the links... I have already looked at many of those posts... the problem is, I don't know which lighting upgrade goes with which part from the website, (except the trunk and license plate, those are easy to recognize). So, I thought to narrow it down I would make a list. Also, some of the members buy their lighting from pepboys, or custom create it. (i.e. the glove compartment) Bottom line... I don't know enough about it to completely understand the other threads and I was hoping someone would explain which are the most effect upgrades and from my list, I would know which part to buy.
Ahhhhh... Sorry... now I understand. Let's try this----
Genesis LED DOME Panels - NO, These appear to be the same as the ones already stock in the Genny.
Genesis LED Floor Module Set - This would be a good one, but I felt it might be TOO bright, so I used the PepBoys Pilot module here. VERY easy fit.
Genesis LED License Plate Module - YES - This is the first change I made with the KAI modules. They are VERY VERY bright and the color looks great on my Platinum Genny.
Genesis LED Fog Lights -Haven't done this one. A bit pricey for the little amount I use fog lamps.
Genesis LED MAP Panels- No - These appear to be exact replacements for the OEM.
Genesis LED Trunk Module - YES - This was the second mod I did and I LOVE the fact that the trunk looks like daylight at night.
LED Mirror Signal Lights -NO- Might be interesting to do some time, but I feel it is redundant... The Signal Repeaters on the front side of the mirrors do verry well since the wrap to the sides and can also be seen from behine the Genny.
Genesis OEM LED Signal Rep-NO- These again are the OEM parts. No change if you order them.
LED Side Mirror Ground Lights - No- I beefed up the under door lights with the PepBoys Pilot modules the flood the ground with light. The Mirror Ground Lights are also called 'puddle lights'. They MAY help if you wind down the window and look out, but by the time you open the door, that light is lighting the ground where you won't be stepping! And, it appears to be a not so good mounting method.
Now... having said all that- I like the KAI guys a lot. They have given me spectacular customer service.
I may have not answered all you're looking for. Feel free to ask more or send me a private message and I'm happy to give you my number if it's easier to talk.
THANK YOU!!!! This is exactly what I wanted!!! Thank you for spending so much time and going though my list! I now know what to buy. Whew! I appreciate your help so much!!!!
One more question... how do I find KAI? Is there a website other than the link I provided that you recommend?
