Nikgen
- Jul 8, 2014
Yep. You will be able to stop .1 mm shorter than me.
Having to buy a new set of winter tires from scratch, the parts in bold/underline from the Tire Rack Blog below are why I will buy the LM-32 over the LM-60 - has nothing to do with stopping 0.1 mm shorter as, in many years, much of our winter in NJ is just cold with no snow or weeks between snow with clean roads - and I don't plan on continuously swapping wheels all winter!
"While the Bridgestone Blizzak line has always been known for its top-of-the-class winter traction, it has given up ground recently to some models that offer competitive levels of grip, but tend to handle better on dry or wet plowed roads.
The new Bridgestone Blizzak LM-32 aims to pick up where the LM-60 left off while increasing steering response and dry road handling. Offered in numerous sizes and featuring speed ratings as high as W (168 mph), the new LM-32 should be at the top of your list if you are looking for a tire that can handle most anything winter throws at it, while still being pleasurable to drive on when conditions aren't as nasty.
Higher speed ratings traditionally correlate directly with on-center feel, lane change responsiveness and sidewall rigidity. The higher the speed rating, the better the tire typically performs under such criteria. With that said, apart from a higher terminal top speed (LM-60 is H-speed rated for 130 mph), the new LM-32 looks to be a better handling tire than its predecessor, but still retains the aggressive directional pattern the Blizzak line is known for."
