I thought I would start a new thread because we were getting a little off topic in the Dead Pedal issue. To summarize my last post, I tried to prove, using math, that the the demands of the engine were greater than what the under-hood induction system (UHIS) could provide.Hence, the need for a secondary air door (flapper door) Some speculated that I didn't take into account enough factors to make the data valid. To a certain extent that was true. The air ingestion rates were based on a 100% efficient system with no bends, leaks or obstructions. I thought that it was much less efficient than the numbers suggested. But, I had no way of proving whether it was 50% or 90% efficient without a flowmeter. Some speculated that ram air pressure would be great enough to close the flapper door at speed. I thought not!
So I set out to do a little experiment with the flapper door. It's a simple electrical continuity test that others should do to validate the results. Here goes.
Purpose: To determine if the flapper door closes at any time during wide open throttle (on a 5.0).
Materials: 15 feet of wire, 12 volt bulb, two contacts, a 12 volt power supply.
See pictures that show bulb on when flapper door is closed. Bulb off when flapper is open.
Method: Accelerate from 35 mph to about 105 mph. Do 2 runs; each one in opposite directions. Also, accelerate at part throttle to determine when flapper door opens. Note: Ram air pressure is negligible below 35 mph. I picked 105 because our trap speeds in the 1/4 mile are about that.
Observation: When throttle was opened the light immediately went out and stayed out up to 105mph.The light came back on when lifting. This was repeated in the second run.
At 2/3 to 3/4 throttle the light would go out at 4000 rpm...until lifting off.
Conclusion: The engine needs more air than the under hood induction (UHIS) can provide.That's why we have a flapper door. Vacuum overcomes the magnet, spring and any ram air pressure that may be in the system.
"THERE IS NO RAM AIR GOING ON HERE!" Sluggo, you were right!
