Switching out the trunk H for the wings
I placed the wing on the top of the H when it was removed, centered and taped it . I then put the H back together with the wing, from there, I taped the two ends of the wing. Marked its location and the rest was a perfect de-badging.
That's the best, easiest method I've heard yet. :)
And make sure you get the one that matches the color of your front emblem. My car is black and has black emblem. I got a deep blue emblem, didn't know it had different colors then, so I put it on. Now a black one is on order.
So, I have a question on how the wing should look on the rear. The dealer installed the wing on my 2015, but as I looked at the finish job, the wing is not flushed on the car. It looks as if there some sort of double sided tape centered on the wing, therefore the wing protrudes from the car Is this how it should be?
That's how mine looks - it looks like they use a thicker tape than necessary.
Could you guys post a pic of your setup so I know what to avoid.
I'm not sure what you would like to see. We're only saying that the rear wing emblems seem to use a slightly thicker than necessary mounting tape. There are no options and nothing to avoid. It's just the nature of the beast. :)
Received My wings....
I was wondering now in the freezing midwest if there is any issue with the 3M adhesive that I would need to wait for a warmer temperature range to apply the wings?
