ckon
- May 3, 2010
- Location
- SE Michigan
- Genesis Model Year
- 2021
- Genesis GV80
He texted me a response to your question:
"From the headlight beam to the center of the front emblem is width. Height is floor to center of the headlight beam. Should be 28" height and 27" wide from center."
There's also a certain distance to the measuring surface that has to be specified to make the adj accurate. Did he say what it is? Can he send you the diagram showing the adjustment parameters (distance from vertical surface, height, width, measuring points, etc.)? Then we could actually do these changes accurately instead of just guessing.
