Billfz1
- Nov 28, 2012
This is a complex issue, but I have the following comments:
- Brake Fluid is not anything like motor oil. It does not reach high temps that cause burning off of moisture unless the brakes were overheated.
- Driving a lot of miles and getting the engine to full temp does not impact the brake fluid. For example, if you were driving Hi-way miles with little traffic, you wouldn't using your brakes much. In fact, brakes can get as much, or more use in city driving during short trips than on the highway.
- The fluid recall was to switch from DOT-3 to DOT-4, which also had some anti-corrosive additives included in it. But the basic problem was a design defect (corrected by Continental Automotive in 2010) in using zinc platted values in critical parts that were prone to corrosion, according to the lead investigator on this recall for the National Highway Traffic Safety Administration (NHTSA) .
Mark,
Some but not all of what you said is true. Engine oil and brake fluid are different things sure but both are subject to heat cycles and in some cases brake fluid has a tougher job. Brake fluid will often get quite hot, though mostly close to the caliper. Most brake fluids are designed to suspend water but final boiling points vary. the fluid in the calipers can easily reach 200°F, more on a long mountain downhill. This does not require abuse. Parts of the braking system with poorly designed or finished parts usually still need the presence of a corrosive to start the breakdown process. Water is still the most likely contaminant. That is why there is a recomended change interval. If you run ceramic pads, or any high friction pads it is worth considering a better brake fluid. The calipers can easily see 300° under hard use or on a track day for example. The irregular heat cycles of infrequently used cars do cause condensation. Most fluids handle it easily. Some do not. We do agree if you are just on a long straight drive the brakes don't get very hot. It is surprising how hot the fluid in a caliper can get with just a small amount of use though. This is moot since the bad part has already been discovered. Many of us will never get even close to the limits of our cars. Probably a good thing, but some of us buy "high performance" cars for a reason. if you use that capability it is on you to be sure to do it where it is safe, and that your car is ready to handle it. (The track is by far the best place for this behavior.)
Bill
