De-badged and rear Winged!!!!!
Where did you find the instruction on how to remove the old badge and how to install and realign the new one?
There are now 2 different trunk emblems available on eBay for the 2015. Will either of these fit in the guide holes left when the flying H is removed? ImageUploadedByTapatalk1423959537.374845.webpImageUploadedByTapatalk1423959547.886037.webp
Thanks, but after comparing them closely, it looks like this one with the correct tab for the US version is smaller in length . Pix if you have the chance ?:)
I think it's just the way the pictures were scaled.
Where do you get the trunk lid wings. What material are they? Plastic or metal?
Same question here. Comparing eBay photo of alignment posts with snapshot of trunk alignment holes from installation video doesn't give me a warm fuzzy either. Could be photo scaling too, but posts appear oversized in diameter. Anyone used this "new" wing badge? Just asking before I buy.
I tried to scaled them both the same. If you focus on the reflective sticker size in comparison to the overall size, they look like the same size. The post are definitely thicker on the lower one. ImageUploadedByTapatalk1424098631.234579.webp
There are now 2 different trunk emblems available on eBay for the 2015. Will either of these fit in the guide holes left when the flying H is removed? View attachment 5077View attachment 5078
A bit more searching on eBay shows that the first photo is actually the front emblem, offered under the wrong PN. The second is the Korean trunk emblem. The front is a bit larger, might (?) work OK on the rear, anyone tried?
The top one is the Korean trunk emblem and the bottom one has the correct posts for US. I used the top one and had to dremel off the posts.
So, I hear talk of putting the fogs in, but has anyone done done it? I don't see a thread specific to the 2015s. Where do you source them? Somewhere in KDM, I have to assume?
Check these out, I bough them. You just have to wire them to your own switch or a relay.
http://www.ebay.com/itm/201248065935?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Yes, I found them. Be very careful of sellers with single (LH/RH ONLY!) listed for $230-$250 + $40-$60 shipping! I agree - wired "hot" is the way to go. Has anyone figured out how to make the "eyebrow" / "positioning" LEDs always on?
I found the "card key" I mentioned here yesterday (elsewhere): http://www.ebay.com/itm/OEM-Genuine...Parts_Accessories&vxp=mtr&hash=item3cebb27477 - sorry, clearly OT in this thread...
Good news!!!!
Debadged and Wings today. Took about 20 minutes start to finish.
I may have set the Wing badge a little low, but it is flush all the way around.
picture.php
Initial thread showed other badgeing removed. Can I imply that that the Genesis and (in my case 3.8 H track) badges can be removed without leaving holes underneath ie. where the happy H has two pins the other ones just stick on without pins? Thanks.
No other badges have pins so there will be no holes when you remove them. Good luck.
