Dash cam?
FastDEW1
Not sure if this is a good place to ask - but do any of you guys use a dash cam? I run a lot of miles ever week, putting over 150 miles per day on my Genesis. Seeing a lot of accidents lately and bad driving in general. Has me thinking I might want to run a dash cam. But I know little about them. Looked on eBay and a few other sites and see pricing and features all over the place.
Do any of you use dash cams? Any suggestions or recommendations?
I know that few people on this forum (including me) use dash cams. I suggest you go to this great website and read information: https://dashcamtalk.com/. Decide what dash cam you want and then visit forum: https://forum.dashcamtalk.com/.
I personally have four Mobius dash cams, two in my Genesis (front and rear) and two in my wife's minivan (front and rear). If you decide to go with Mobius and need information from me about my setup just let me know.
6 reasons you should own a dash cam:
http://cameras.reviewed.com/features/6-reasons-you-should-own-a-dashcam-2
Great topic! I'm current using my Galaxy S5 as a dash cam (HD video, wide angle). I'm deciding between two different dash cam apps: DailyRoads Voyager and Caroo. I like DailyRoads, but there is a ~4 second gap when it is rotating files. I just started using Caroo today and I believe it is gapless.
Any suggestions for dash cam Android apps?
I must admit the Garmin 20 is solidly built compared to other plastic lightweights I have seen. Go with a Garmin 20. It has all the bells and whistles. $200 bucks and it has Impact registration, GPS location, Time saves 4 min before crash, the crash, and 4 min after the crash automatically. Some NEW driver passed me and two other cars on the right shoulder at a horrendous speed. I saved that clip and emailed it to the RCMP (cops) and they hunted the driver down and ticketed him for dangerous driving and removed his licence for 6 months. This unit has definite multiple uses when driving. I have two in both my cars (front and rear)
Kevin
Wow. Thanks for the replies. I have read a lot on the links you all provided. I was hoping this would be more simple. It seems most of these cameras are not very reliable. They show guys taking apart even some of the "best" cams to repair them. Thats disappointing, as I was hoping I could get something of quality and not have to mess around too much with it. Seems thats not really the case.
I have a very simple and inexpensive dash cam - my iPhone on a windshield suction cup mount, running the $0.99 app "Witness". It records in HD, with or without sound, saving up to 10 video clips of up to 6 minutes each. It will automatically over-write the oldest clip unless you elect to lock-protect that one. It also records speed, compass heading, and GPS-derived location on a map so you can see just where you were while recording. Finally, to protect from forcible deletion of videos recorded, you can require a PIN to enable deletions. Videos can be uploaded to your computer and edited using any video editing software. Normally I have my iPhone on the windshield mount, recording everything that happens in front of me.
Interesting. I did not know of the App "witness".
If you get a phone call, does the Bluetooth feature work?
Warreneaux
P.S.-I just found out it is no longer available.
Thanks
How do you keep the camera from interfering with the rear sun shade?
I also use rear sun shade and it was my concern because I wanted dash cam for the rear windshield. So I made custom mount. Check attached images.
I don't want to pay 200$ + just yet. I just ordered two cams. Spy-Tec A118-C and Spy-Tec G1W-C. These are capacitor models so their is no battery inside which means they wont get hot and explode inside the car. They are rated at 140 degrees. I like the smaller A118-C better because of the size but it seems to be not has popular. Going on a long road trip this weekend so I will see how it goes and report back.
Thank you for the heads up. I just looked at both and the smaller A118-C looks very interesting. Is it small enough to fit behind the rear sunshade and still allow the shade to go up?
It might. That I will test and hard wire. If this one does well that is the plan to outfit 2 in the Genni and 2 in the Ram. Hopefully it will and be able to use the shade.
Looking forward to hearing your feedback on this! Thank you :)
Here is half my review on the cams, G1W-C & A118-C. My wife drove the Genesis a few hours more Northeast than i did from Nashville Friday. She is still there on the acct of having to go to the ER and still is there so I haven't gotten the G1W-C yet. As soon as I do I will review the footage and post my thoughts on that.
This part of the review will be of the A118-C in my Ram.
The A118-C surprised me a great deal. I wired it directly into my rear sliding window switch after trimming some wires and stuck it near the bottom left of the rear view mirror on the wind screen. I have a tint strip about 8" down so i didn't stick it on my tint so it sits about 2" below the edge of the mirror from the lens.
The fitment was good on the windscreen. With the sticky pad on it fit nicely just below my tint strip. I did put a piece of red label scotch clear gorilla glue like tape on top of the OEM sticky pad just in case it would want to fall in the heat so I cannot say if the OEM was good enough or not. Other reason I did it was because the scotch tape is about 1/16" thick so in the case of removing the cam from the mount it has a little bit of stretchyness and will not eventually start to peal off. Popping the cam off the mount seemed effortless as well. Just a little push up and it comes right up but stays on the mount very snugly. I like how this one lets me adjust the level of the lens and not have to adjust the camera as opposed to the G1W-C. Just get it straight on the windscreen and you can move the lens where ever you want, north to south.
The A118-C recorded flawlessly. Initially set on 720-60fps, on a 5 min loop it recorded every second of the 2.5 hour drive. The 5 min clip took up 270mb per segment and no time in between each segment was wasted off the clock. This surprised me. It ended at for example at second 54, and started the next segment at second 53. It actually stopped and started each segment one second before the other previous one ended. No five seconds in between while it was filing away a file. This was a nice surprise.
The next part is about image quality of the video. First I used the 720-60fps. Most everything was fine. It was clear sunny sky's both days and I could pick up everything. Except license plates. No matter how close I got to the car in front it wasn't going to pick up clear letters/numbers. Just shapes. So turned it up to the 1080 for the Monday commute to work and it was like going from SD to HD. Obviously. In 1080 it picked up license plates, all road signs, everything. This is the way to go. I do have a kingston 32gb Class 4 card in each one for reference by the way. The 720 mode recorded a segment at 270mb. While in 1080 each 5 min segment turned into 571mb. More than double but well worth it. On Sat and Sunday I did have the exposure set to factory settings. For Monday I did go down to a -1/3 to darken it up some. It did darken and I think to much for the purpose. We did have some low dark clouds but it wasn't that dark at all. I will switch this back to an even exposure.
Sound. The sound works good. Maybe too good. For 2 hours Saturday morning i had my radio down so far I could barely hear it. It came thru to the cam like i had the stereo plugged into it. It picked up cars driving by on the interstate with all my windows up, and some of my factory exhaust if I took it off cruise and had to step down on it some. It will pick up the turn signal blinker sound which may be useful if you were in front of a Judge however.
The time stamp, date and time were good, accurate and didn't change anytime. I did unplug several times just to check and it stayed accurate. The file name even records the time it stopped and in a way the time it started. You just have to dissect the file name a little to see it.
The menu's and firmware was the same on each cam with the exception of a version number difference. There are firmware updates but I did not go that route at this time. The menu's were the same and seemed easy to navigate. Once you learn what button does what, it is very simple. The limited instructions that came with each one is just enough to figure it out. There are some more detailed and to the point instructions on the net written by other users.
I did not use the picture taking mode nor did I hook it up with the HDMI.
I am in the process of uploading a 720 and 1080 video on youtube. Once it uploads and I assume scale down the graphics I will post the link. Here are a few stills of each.
When I get the G1W-C back I will do the same.
The fitment was good on the windscreen. With the sticky pad on it fit nicely just below my tint strip. I did put a piece of red label scotch clear gorilla glue like tape on top of the OEM sticky pad just in case it would want to fall in the heat so I cannot say if the OEM was good enough or not. Other reason I did it was because the scotch tape is about 1/16" thick so in the case of removing the cam from the mount it has a little bit of stretchyness and will not eventually start to peal off. Popping the cam off the mount seemed effortless as well. Just a little push up and it comes right up but stays on the mount very snugly. I like how this one lets me adjust the level of the lens and not have to adjust the camera as opposed to the G1W-C. Just get it straight on the windscreen and you can move the lens where ever you want.
quality obviously went down some upon uploading the pics to the forum.
Vids
The first one is Saturday morning with even exposure and 720-60fps
Second one is Monday morning at a -1/3 exposure and 1080
I listen to sports talk radio so that is what you will hear mostly. Like I said it has great sound pickup. Also there is a finger smudge in the second video on the lens.
http://youtu.be/M_zYZ0VNYUc
https://youtu.be/86wy4EFnqFE
^^^ 👆👆👍 thanks so much for the time and effort of the test and reports back... Amazing. Big help for me.
Review of the G1W-C.
Below you will find some still pics and 1 link to a video.
This cam actually did ok. This was not a direct wire as I wasn't able to get it directly connected to the power yet and had to use the electrical 12volt connection for the power before my wife left.
The fitment and blend-in part of this cam I didn't like. It just kinda hangs down below/beside the mirror off the suction cup of the windscreen. Most of our power mirrors these days have a large housing to hold wires and connections for coms, sensors, etc so its hard to hid something this size behind there. This is about the size of the really old slim flip phones. About the width of a deck of cards and about the same length but half the width. The space the mount takes up is the main issue I have. Suction cut, arm, mount. Too much there to try and hide. A sticky mount solution would be a better option and wouldn't be hard to make. I know about the arm that hangs down and attaches on the mirror bracket which would be better, but not overall appealing. Forget about trying to remove the cam from the mount when its still attached to you windscreen. I didn't want to remove the suction cup when I first went to retrieve the cam so I unscrewed the tightening knob and pulled the arm out of the ball. That was much easier.
The recording was good. This was set at 720 and picked up license plates and signs better than the A118-C on that setting. My wife didn't change the setting to 1080 during her trip. But apples to apples it could be and may be just has good or better than the A118-C. I did have a few files that would not open and play. Codec issue it said. But that was on about 3 of about 50. 6%, not good and not what I wanted to see. May not be the cams fault however. A Kingston 32gb class 4 card was in the cam as well. 720 recorded a 5 minute clip with a file size of 284 meg. A little more than the A118-C. I would assume on 1080 the file size would be similar if not a little larger than the A118-C. This may also be because the image may be somewhat cleaner. I will test both this weekend side by side to see.
The sound worked well. Not has strong or sensitive as the A118-C but overall a recorded sound that I would rather have.
The date and time stamp worked well. The file structure was a lot different in how it made files. My first video started at 5/8/2015 at 5:45am. The file name that was made is 10250508. The 1025 part of it I don't know if that is a generic # it made but obviously the 0508 part is the day. The next day, created a 2nd file which was 10350509. Started recording at 5/9/2015 at 9:59am. So a little strange on the file structure. Inside those file folders are the actual files for the day. Those start with the time, 0545 and end with a generic 0001, 0002, 0003 and etc until no more files are written for that day. I do prefer the filing structure on the A118-C over this one. It shows complete date, time in the file itself.
The cam seemed a little dark out of the box on an even exposure but that may have just been the low light for the morning. It seemed to brighten up that afternoon.
The menu is fairly self explanatory. Just scroll thru before you pop in a card and check out what each thing does. The instructions are a little more detailed, but still lacking in the over all help part of it. It is enough to get you off the ground.
One thing I did notice was the memory card had popped out after the 2nd day. I don't know if this happened when my wife was retrieving the cam from the windscreen or if it did it on its own. I will use it this weekend and see and leave it up to see how it holds up. Because of that I only have 2 days of footage out of 7.
For my money, 70$ bought the G1W-C and 80$ bought the A118-C. I want to like the A118-C better and I do. The size, better placement, easibility of removing it from the windscreen, easier buttons, however a little small. The G1W-C may record video a little clearer, but the A118-C did good enough on 1080 mode for me to justify wanting to use it because of the size and better ergonomics. I also am not giving out a plug or recommendation but I bought both cams from SpyTec, via Amazon. I wanted to make sure I bought quality cams and no fake or clones.
I will travel around with both side by side on the same settings and if something else sticks out enough for me to sway back to the G1W-C as the better cam, I will report it.
I will not try to install the A118-C in the rear windscreen to see how the sunshade will affect it and to see if the sunshade can even be operable with it installed.
https://youtu.be/Bnq2O1-PPKw
