Jonah, sorry to hear about the problems you encountered. Regarding the fuse box, I removed the top of the fuse box first. My recollection is that there are two bolts at the rear of the box and one bolt at the front of the box. I removed all three which allowed me to nudge the box toward engine centerline one or two inches. That little bit allowed access to the high beam cover cap.
My earlier reference to the "convoluted spring clip" was in response to scottdk's comment regarding high beam bulb replacement. I hope my comment didn't imply that the high beam bulb needed to be removed in order to replace the position lamp. It does not! Having done it once (and on the driver's side no less), I will never again remove that clip unless absolutely necessary. Toward the end of the week I'll again be removing the air filter housing and, if you can wait that long, I'll take some macro shots of the spring clip in place.
Couldn't agree more on the LED issue. For a lousy three hundred bucks or so, all of the interior and exterior low-wattage lamps could have been LED vice incandescent. It's like Hyundai went only halfway. On the rear of the car, for example, they went LED for tail light, stop light, high-mount stop light, and side marker. Then, incredulously, they slapped a big, orange, incandescent, turn signal bulb in the middle of their beautiful clear housing! Can you say "fried egg"? Even the Cadillac CTS has LED turn signal lamps! Interior lamps - same story; Hyundai went only halfway. I feel a rant coming on, so perhaps I should stop. Don't get me wrong; I absolutely love my Genesis! These are small nits I'm picking.
