Hey guys, let me start off by saying that hyundaitechinfo.com is not free as mentioned in some other posts, so I'm hoping I can get some help with the following:
- Removing door panels
- Removing the felt material at the top inside the trunk (under the sub)
- Removing roof liner to get to the bare metal
If anyone has tips or links, please let me know!
Background:
I find the Genesis is a great car and very quiet, but it could be better. Compared to my Maxima, it has quieter glass and the aerodynamics/plastic/felt bits help a lot, however it still has more road noise (which I'm sure the tires have a lot to do with) and exhaust noise. I checked and the trunk basically had 0 soundproofing and dampening materials and this is likely the case for most of the car, so I feel like there's room to improve here. Since the nice design means no visible bolts/nuts/screws in most places and I couldn't find any videos or instructions on how to get to the door metal, subwoofer, roof and floor without guessing my way around and breaking things, I figured I'd ask here. I did see one crazy 600+ pic soundproofing job on a Genesis but I didn't see how he actually removed the covers to get to the metal.
What I did so far:
After obsessing about cheap soundproofing and learning about it for a month: In the trunk (bottom and lid), I ended up using some Dynamat style material for vibration absorption (Covered the middle of any large flat area that vibrated easily) then foam over and around the spare wheel to absorb sound, then a layer or MLV to block sound (Covers the same area as the default trunk felt liner). It worked very well, it killed any echo in there, ate up some vibration when I turned up the music, and it made it so I hear my engine a lot more than my exhaust when I floor it. (I love the way the V6 sounds, but I used to hear the exhaust at the back of the car a lot better than the engine right in front of me which made no sense for a big sedan)
^^ I cut the sound blocking material to the shape of the trunk and added foam under it since this pic.
^^ There are hollow areas I could fill up with foam but I didn't find much sound really ends up in there nor does it vibrate that much so I didn't spend much time on this.
What I would like to do:
- Same thing to the doors (at least MLV as I hear they're padded nicely already), floor, roof, wheel wells and under the floor mats if doing the entire floor is too complicated.
Background:
What I did so far:
