Car does not accelerate when giving gas
martyk
Taking my 2012 4.6 in to check the trans. When we where going to Vegas I would pull out to pass a car, and give it gas the. The car would sit there for about 2 to 3 seconds by for exelerate. Does anyone have this problem.
Regards, Marty
Re: Car does not exelerate when giving gas
Funny, Exelerate is a Danish band.
Regards, Marty
2 to 3 full seconds sounds like an awful lot of time for a delay.
How much throttle do you give it? Enough to cause a downshift or just a little bit?
If you floor it the transmission will take a second to find the right downshift gear and that may be your hesitation. Try using less throttle or downshift manually then give it the gas.
OP: No it's not normal.
My '12 4.6 will (and my '09 4.6 before it would) go from 70 to 100 in about 5 seconds with about 1/2 throttle and a manual downshift to 7th or 6th.
If I push the pedal to (but not past) the kickdown stop and it'll down shift a couple clicks automatically and get there a second or so sooner.
I usually don't bother putting it all the way to the floor. Usually just scares the passengers. :D :D :D
The"dead pedal" sound like my issue. Hesitant shifting and gear hunting. I will be taking it in tomorrow for a check up. I hope it is the TCU software update that will correct it.
Thanks for your help,
Marty
I got my car back Thursday. They found a update for the shifting problem. Now I will have to see if this is going to fix the "dead pedal". Will get back to the Forum.
Marty
Funny, my genny does this sometimes when leaving a light...scary...
Did they fix it, Marty?
Not sure. I have not had any time to take it on the freeway. They said they found a software up date. I ask what it does, he did not know. They did clear out the ECU so the car would learn how I drive again. Will get back to you after I get it on the Freeway, where I can open it up.
Marty
