OneFunGenesis
<- Runnin' on Empty
sweet, thanks! Links to where you got your acoustic foam?
The car lovers social network
Automotive components
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Explore Pet Insurance!
The Food Order Method
Advertise with us!
Absolutely! I should have a few days with the car and no girlfriend later this month so I plan on working on the doors next.Do you have any plans to do anything to the doors? This is where I hear a little bit of noise and would like to improve it - if it is easy enough to dohint hint... wink wink..
BUT, it won't affect window noise at all, and unfortunately that's where I hear most of my noise from (mainly some wind noise at high speeds or sometimes a loud car passing by).
I'll try it out and let you guys know if it's worth doing or not.
Thanks guys! All the mods and repairs I did to my previous car were thanks to people posting how to's online, so hopefully this saves people some guess work.
However, here's what I realistically expect: The doors will probably make more of a thud when they close (although they don't sound hollow as it is), and they will block more sound. BUT, it won't affect window noise at all, and unfortunately that's where I hear most of my noise from (mainly some wind noise at high speeds or sometimes a loud car passing by).
I'm not aware of any way to make glass quieter as it's already "soundproofed" by Hyundai, but if there is sound going under the window/glass and bouncing around inside the door, that echo should get absorbed...So maybe it'll make more of a difference than I expect? I don't know, but I'll try it out and let you guys know if it's worth doing or not.
I had spare memory foam so I basically filled up space like this around the tire to cut down on exhaust noise:
/QUOTE]
Is this memory foam a member of the acoustic materials set you published the links or some spare you had at home?
I like the idea anyway. Could you please provide a link?
I understand it is not glued at all. Right?
Gotta wonder how much weight all this sound deadening adds to the car?
When we used to strip the deadening material from "racecars" back in the day (DSM factory sprayed in goop), it came to ~10-12lb. Nothing too crazy.Gotta wonder how much weight all this sound deadening adds to the car?
Thanks but I'm actually just a guy who did a month of research before taking apart an interior for the first time, so anyone can do this!You are obviously an expert on what you are doing
Yeah, this is something a few cars do which is exactly what Active Noise Canceling headphones do and I wish all cars had it because it's so simple.in their effort to make the LS-4XX totally silent, used a different approach to this kind of continuous wind related noise: an electronic neutralizing sound that is generated after "hearing" the noises. Any knowledge/product to be shared here?
Looking good!So I took a shot at this today. I picked up some Peel & Seal from Lowes for $17 and went to tearing the car apart.
Good question!Gotta wonder how much weight all this sound deadening adds to the car?
