air filter clips
ppg677
Dumb question-- what's the deal with the air filter on a 2013 3.8L Genesis? I undo the 4 clips and I can't really remove the cover. There is an electrical cable that goes taut.
Also where is this so-called flapper that causes a dead pedal?
Inside that box that you are trying to remove the cover off of, under the filter element. And I believe the electrical cable has a handy connector right next to the lid that you can dis-connect easily.
Are you saying that the flapper is below the air filter? If so, I woudlj't feel comfortably putting any kind of tape below the filter!
I just reversed the magnet. No tape.
The engine pulls from above the filter. You wouldn't want tape above the filter.
Remove the magnet. That's what I did.
