Hi, I collect my Genesis in a few days time, so been reading through the owners manual (US version, I can't find a RHD version for the UK). I have a question regarding the Start/Stop button. I've learnt that to start the engine, the autobox is in Park (P) and the brake pedal is depressed, and of course the smart key is in the car. Then I press the button. Do I need to press the button until the engine starts, a bit like keeping the ignition key turned until it starts in a older type car, or is just a quick press/release required? When the engine starts, does the illuminated text above the button show 'ON'?
Also, without pressing the brake pedal, I can step through ACC and ON. Presumably with the engine running, the button shows 'ON', so a further press will turn the engine off? Again, is this just a quick press, or is it a hold until the engine stops?
Regarding the electric parking brake, is it normal to press the AUTO brake button and just simply drive around with this feature active? When parked, presumably I apply the brake with the push/pull switch. When starting a journey, do I use the push/pull switch to disengage the PB and then push the AUTO button? Or does the AUTO button override the push/pull switch, so the PB would disengage when moving?
BTW, when the PB is engaged, is it slowly draining the battery?
Nick
Nick
