Mark_888
- Jan 9, 2009
Yes the Honda/Acura transmission from about 2002 had a lot of problems. Those problems were fixed and it is now 2016, 14 years later.I had a 2002 TL TypeS. 3 Transmissions in less than 2 years so I traded it in. Although they were highly rated mine was a piece of crap. Had to have the entire car repainted (defective paint) Throttle body needed replacing before 1 year. The drivers side door lock failed and like I said, three transmissions. I did quite a bit of research into this back then and although Honda is a very good reputation, their transmissions are in the Lada league.
The latest Acura transmission problem was on a ZF 9-speed model, usually considered one of the most reliable transmission brands in the world, and used by a lot other car-makers. The 2009-2011 Genesis 4.6 V8 used a 6-speed ZF transmission that was pretty much bullet proof.
The 2009-2011 Genesis 3.8 V6 used an Aisin 6-speed Transmission. Aisin was a joint venture between Toyota and Borg-Warner to build RWD transmissions, and was used on Lexus and other cars. Based on member feedback, this transmission has also proved to extremely reliable.
The 2012 Genesis 8-speed transmission had some "early" problems, and a fair number of them were replaced under warranty (based on member feedback).
