Did my first oil change from the topside. Used my 27mm socket and my shop compressor oil evacuator. The evacuator got just about all the oil out through the dipstick.
After the oil was evacuated I unscrewed the filter using the 27mm. It was difficult to work in the confined area. I did put a small tray under the filter and got out about 5 tablespoons as the filter came out.
Screwed in the new filter but I was unable to have enough room for a torque wrench so just gave it the tighten then another 1/4 turn. Leaked check okay.
Next time I will put the car up on ramps and remove the front engine protector. Should make it a lot easier and I will be able to torque it to specs.
Took about 7.2 quarts. Used Quaker State Ultimate Synthetic 5-30
