The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Did you try a Hyundai dealer parts department?
https://www.amazon.com/gp/product/B004QQ04PU/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
They look exactly the same and work great.
Be careful, The Amazon link above is $8.99 for only ONE CLIP!!! No where in the Description does it say for More than one....Somebody is making BIG MONEY on that one!
The title of the object says 15.![]()
So, these clips must be removed to replace the engine filter?
On the G2 V8 - you have to remove a large front panel to access the oil filter. Remove five 10 mm cap screws & 11 plastic push pins -- They are not really clips - the pushpins are cheap little fasteners which should be discarded and replaced.
And, on the V8, that procedure is just for starters - a second centrally located panel has to be replaced to access the oil pan drain plug - the way to go on that one is to use the "Mercedes Method" I.E., suction the oil out with something like a Mity-Vac or the equivalent.
But -- If you are really a "No Genesis Yet" person -- then why Worry.
What about the engine air filters for the V8?
