What is this hose???
ealexander0231
California
Hello guys!
I'm new to the forum and this is my first post! I plan on learning more and more as I go and spreading info when I can.
I have a question though. I'm not a mechanic by any means, but I am a DIYer and a car enthusiast. So, anybody can chime in if they know what hose this is as I am completely clueless. However, I changed my serpentine belt today and noticed a lot of leaking under my car. I went under my car and I sourced the leak coming from this hose:
Is this normal? I dont want to keep driving if it is not normal. Any info on this would be greatly appreciated. BTW the car is a 2010 Hyundai Genesis 2.0T Manual Trans. Thank you.
Tranny coolant line hoses? Does it run to the radiator?
No, it doesn't. Is it supposed to? If you look at the picture, it's roughly about 3-5 inches and it doesn't seem like its connected to anything. it seems like it has either been cut or it's designed to be some type of "drop off". I'm not sure.
Don't have a coupe but guessing by it's location that it is some sort of condensation drain from the A/C or cowl area. Test what is dripping from that hose and it will give you the answer.
Looks like the condensate drain for your A/C evaporator
Since you're in Calif., you must be using your A/C
If the substance coming out is nice clear water, then that is almost for sure what its is.
Usually when you drive your car during hot humid wx, after parking it, then a few tablespoons of condensate will be dumped.
Actually, it's a great functional test as to how your A/C is functioning.
