KDM overhead console w/ mood light
khorhadris
Had a chance to get this baby installed onto my 2015 Genesis..
Had to do some soldering but worth the effort.
Part no.:
92810B1000SG2
I had a chance to fly over to KR and asked around to get this in my hands.
Cost about 130,000 Won or $155 CAD.
The unit itself is basically plug-and-play but mood light doesn't work since it involves BCM (Body Control Module) - basically there is a menu option on KDM models to turn it on or off.
I had to run wires to ILL (+ and -) to have it turned on when headlights are on.
couldn't you just tap the power source for the LED light that shines down? that's only on with the headlights too.
That's what I did, running wires to ILL + / - located at the jack - I bypassed the Mood+/- jacks which require BCM comm. and soldered them to acc. power source.
Just different wording. No wire modifications are hanging out of the overhead console unit.
And no, you can't just wire them to led behind the sunroof switch as these mood light wires are a set of two wires. I couldn't find feasible wires that run to the led light you are referencing to.
I wonder if the mood light could be turned on under the engineering mode? I noticed some things under the menus like the rear video players that we don't have here in the USA. I'll check in the next week.
Negative, already looked there.
Soldering was my last option on the list.
Below is the overhead console jack diagram I referred to.
so you jumpered pin 4 to pin 2? or pin 3?
also, does anyone know how can we get our hands on this part number in the states? google search only turned up a few russian sites.
I found wires from mood light LEDs and soldered them to 2 and 8. (ILL + and ILL -, these are powered only with acc. mode or engine on mode )
It might be a good start to look for those Ebay sellers who stock KDM parts and throw a directly inquiry to them.
How is the light now that you've had it for awhile? Is it intrusive being too bright?
Actually not at all.
Navigation screen is way more intrusive than this is. Liking it so far!
hey bud are you on Facebook, I have a few questions since I want to do this mode
