I would try and find a suspension shop that will do an alignment that starts with specs, but then test drives the car multiple times and makes manual adjustments to get the real world alignment correct. You will have to get brand new tires right before this is done.Well it looks like I'm having the same camber issues. Inside lip on my tires is worn bald. Shop said they could not adjust the camber. Everything else is in spec. I need this fixed before I replace the tires...
YesIf you are interested in camber adjustments for the sedan please respond here.
Front and Rear
I need camber adjustment for my 2009 Genesis Sedan 3.8L. Does that exist? Available to purchase? Thanks.If you are interested in camber adjustments for the sedan please respond here.
Front and Rear
Would you have a link or website please?? Thanks you! I think so many people would praise you for it!FYI - there ARE front camber shims made for the 2009-14 sedans. They are made by SPC, Model numbers 71930 thru 71935 for different correction amounts
It installs behind the wheel on the hub assembly. There are installation instructions out there. Google is your friend. “Spc 71935 installation instructions”Would you have a link or website please?? Thanks you! I think so many people would praise you for it!
Ok I actually found it by looking up “spc genesis shim” I’m trying to figure out where exactly this installs. any idea?
Front and Rear
I this for the 2015 Hyundai genesis 5.0? Front and rear?If you are interested in camber adjustments for the sedan please respond here.
Front and Rear
