Camber kits
Who wants Camber Adjustments (Front and Rear)
  • Yes
    Votes: 9 64.3%
  • No
    Votes: 5 35.7%
  • Total voters
    14
  • Poll closed .
Well it looks like I'm having the same camber issues. Inside lip on my tires is worn bald. Shop said they could not adjust the camber. Everything else is in spec. I need this fixed before I replace the tires...
I would try and find a suspension shop that will do an alignment that starts with specs, but then test drives the car multiple times and makes manual adjustments to get the real world alignment correct. You will have to get brand new tires right before this is done.
Two years later and still nothing... Still wasting money on tires.. Guess it's time for something else.
It's possible to put spacers on the 4 mounting bolts that secure the front upper suspension
plate to the inner wing,
This will give you more positive camber, not much, maybe .25 of a degree at most.
Whos the character on this op? I've research ever where due to the 1.5-1.75" drop from using these crappy false advertising Ark Performance GT-F Springs claimed only 1" drop on 2gen 5.0. Btw struts are also blown. Mike at Ark has not enough nerves to get me an answer.
Anyways need suggested camber kit for these crappy Ark Springs.
Wish there was one for the car... I'm tired of buying front tires... Lol my car is bagged
2021 and still nothing huh??? I am thinking of bagging my car but not if this would be an issue. So for us running stock suspension and needing more camber I think the best most economic solution would be to purchase new front coils as that would take the sag away for a few years and have to worry about wearing tires prematurely.
If you are interested in camber adjustments for the sedan please respond here.
Front and Rear
I need camber adjustment for my 2009 Genesis Sedan 3.8L. Does that exist? Available to purchase? Thanks.
The wear will mostly be on the rear and not the front. We have rear camber arms for the DH models.. I really dont come on this forum anymore due to the lack of aftermarket support from customers on this forum. If you want info then send me a email at G4werkz@gmail.com or send me a DM on instagram at G4werkz.
FYI - there ARE front camber shims made for the 2009-14 sedans. They are made by SPC, Model numbers 71930 thru 71935 for different correction amounts
Would you have a link or website please?? Thanks you! I think so many people would praise you for it!
Ok I actually found it by looking up “spc genesis shim” I’m trying to figure out where exactly this installs. any idea?
It installs behind the wheel on the hub assembly. There are installation instructions out there. Google is your friend. “Spc 71935 installation instructions”
Do you know if the shims fit a 2015 or 16?
