The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Ok... Anyone know if the DVD video shut down, once pulled out of park can be changed in these settings? So the DVD video plays while out of park? That way, I do not need to have that expensive aftermarket module installed. Thanks..
Hey Guys,
Did anyone figure out to get to the Engineering Mode of Hyundai Genesis (2015+) ultimate trim?
Thank you,
Anyone figure out how to get into engineering menu on 2013 3.7 with tech package.....
Follow the video on the previous page, works for my 2013 3.8 Tech pkg.
There are very few hacks available that I know of. What are you looking to access/change?
Looking to change start menu to prada......
- - - Updated - - -
Video on previous page is for 2012 and buttons are different on 2013 model.....
Do any of these settings allow me to turn off my front collision sensor? It is constantly going off and I can’t find the fcs setting or know another name for it to turn it off. Any suggestions?Here are all of the options, I think, based on following these instructions in my car just now. Some are able to be modified, and some are just readouts.
Scared for now to change some of the settings.Some I find curious, though -- Like the DVD Region setting does appear to be modifiable which I'm really surprised by.
Anyone see anything of particular interest?
- System Config
---- Batt. Voltage
---- Speed
---- Save to USB
---- Save to USB (Persisten…
---- Navi Test Mode
---- DMB Test Mode
---- Pos Tracking DBG
---- Print DBG Message
---- Print TimeStamp
---- Internal update
---- HDD CRC Check
---- Ramguard
---- Multicore Log
---- Slow Slide
---- FadeTime Test
---- Get HU Status
---- Sound Tuning Test
---- Gain Source (disabled)
---- Gain (disabled)
---- Navi Voice Gap (disabled)
---- Chime Volume (disabled)
---- DTMF Volume (disabled)
- Variant
---- Country
---- Vehicle
---- CCP
---- System Variant Settings
------- Navigation
------- MTS
------- SDS
------- RSE
------- DMB
------- MMU
------- XM Radio
------- HD Radio
------- Rear Camera
------- Front Camera
------- ECS Height
------- ECS Suspension
------- US Unit
------- AQS
------- Bluetooth
------- Steering Easy Ac.
------- Seat Easy Access
------- Door Lock Sound
------- Radio Region Code
------- Twice Unlock
------- PGS
------- CombiCluster
------- EQ Limo
------- LDWS_Belt
---- DVD Region Code
---- DVD Lang
- Diagnostics
---- Read Active DTCs
---- Read All DTCs
---- Delete DTC Groups
---- Reset System
---- Reset Component
---- Start XdB Test
---- Start Wake Up Line Test
---- Start RBD
---- Diag Component Status
---- Start Update from CD
---- Status of DVD slots
---- GIRO request
---- Get all Software Versions
---- Set delivery settings
---- Set MMI-Lang. to Eng.
---- Switch Fan on/off
---- Control Fan of UTA
---- Switch to DMB
---- Switch to CAM
---- Switch to MMU
---- Switch to MTS
---- Eject All Discs
---- Load Disc
---- Delete Nav.DB
---- HDD CRC Check
---- Learn WRC
---- MOST Reset (Light Off)
---- Delete Navi Persistence
---- Show Credits
---- Disable Pana FIX
---- Enable KTRace on WD_...
---- HD Switch
---- HD Status
---- HDBER
---- HD Performance
---- HD Blending
---- HD Calibration
---- HD Measurements Reset
---- HD Software Version
---- BERMeasurement ON/…
---- Start XMByPass
---- Signal Strength
---- Tuner Status
---- Lock Status
---- C/N Values
---- BER Percentages
---- Reed-Soloman Error Val…
---- AGC Values
---- Current NCO Status
---- SDEC Software Version
---- XM Stack Software Vers…
---- CBM Stack Software Ve…
---- XM Module Software V…
---- XM Module Hardware …
---- Clear XM Chipset NVM
---- XM CBM Module Debug…
---- TTS Test
Tell me everything you knowFollow the video on the previous page, works for my 2013 3.8 Tech pkg.
