I found a little work-around for the photo issue that we were discussing above, just in case you'd like to have some images of your favorite people, places or things for viewing on your G90 screen. If you use one of the popular "renaming" software programs that we were discussing it is very easy to make this an acceptable alternative to the mess that is otherwise created. Here is what I did: I used the software to rename my images so that they are numbered with that number beginning with 3 zeros. I'll explain. When you attempt to look at images that are on your usb drive and that same usb drive also has albums, the album art images will be mixed in with your personal images which makes a mess of things. If you can modify the number of your images so that they start with several zeros this will (in all likelihood) place those images at the top of the list in your car's system for viewing so that all of the album art junk it beneath (but still in the list). I started all of titles for my ranch images to begin with "000 and then have the software follow up with 01-02-03, etc. at the end. So, they look like this: 000ranch001.jpg then 000ranch002.jpg, and so on. Then when I renumbered my images for some other subject I did the same thing but I started those numbers with 4 zeros so that they would be separated from the previous batch, and so forth. It literally took me 2 minutes to do this with hundreds of images in several batches because the software does all of the hard work, you just add a zero here and there. I used a free app called "Rename". I use it on my Mac but it may also be available for PC, not sure. While this might all seem a little silly (depending on who you are what your particular needs are) there are those who could make good use of this. For a realtor who may want to have some images of their premiere properties this would be great, and the cool factor of having this stuff show while sitting in the comfort of this beautiful car is also a plus. I know, this is probably more than most people want to know, but there it is. I hope this helps
