Status
Not open for further replies.
Sal Collaziano
Genesis Motors Forum
Staff member
Florida
JB4 Features and Benefits
• Power gains of up to 100hp and 100tq to the wheels on a stock vehicle
• Quick Plug & Play Installation
• CANbus integration offering unrivaled tuning features and performance
• Runs as smoothly as stock, this is how your car should have come from the factory
• Compatible with all driving modes
• Fuel economy unchanged during normal driving
• Compatible with JB4 Mobile for smartphone logging, tuning changes, and adjustment
• Ethanol (E85) compatible tuning maps
• Able to read/delete fault codes
• Not VIN locked, can be removed without a trace and resold down the road
• Made in the USA
• 5 year warranty
So the RaceChip adds 57 hp and 133 lb-ft of torque. Honestly...I think I would rather have the torque than the hp. This engine already has a lot of hp and fast top speed.
Torque is what pulls from the start and gives you the happy face.
So I think it is the RC for me...for now.
Another thing that is important to me is which one would be easier to install...and remove. I would want to remove it prior to any dealer visits, etc.
From what I have read thus far...the RC has 3 connectors. This one has 2. Correct me if I'm wrong.
Yes, the RaceChip has three connectors. The last time I used a JB it had two - and I believe this one does as well. However, it's simply a matter of unplugging a wire. They're both equally as easy as the other to install and uninstall. One benefit of the JB4 is that you can switch cars, if need be, without having to jump through any hoops with having the serial number unlinked from the VIN it's currently attached to. Though most people are never going to deal with that anyway...
Will anything of the sort be available for the 2.0T?
Yes, it will. It's already available for the 2.0T in the Stinger. I'm sure once the G70 is released in the U.S., it'll be available for both engines...
Quite a few guys in Edmonton on this site, any chance we can do a group buy! :)
And I wouldn't mind hearing from @GenesisYEG as to how Genesis Canada thinks about these...
Depending on his answer I will definitely never buy this...:sneaky:
Genesis Canada thinks they'd consider denying any powertrain-related warranty claims on cars running tunes.
Yeah, just more reasons not to fool with stuff, in my judgment. That Stinger thread was pretty scary.
If the issues mentioned in the Stinger thread occurred, I think a good mechanic would recognize that those aren't problems (like a fused ring) that occur in an unmodified engine. If they say your warranty is voided, I think the burden of proof would switch to you. They decline service. You need to convince them they shouldn't. That's putting the burden on you. And let's be honest, if that scenario played out, they'd be right.
Wrong.
First they have to prove it was tuned. Good luck with a piggyback since nothing physically there if you remove it.
Second...if they can prove a tune...they have to prove it did the damage.
Wrong.
So, you're saying that if you had one of the problems described in the Stinger thread as a consequence of using a tuning chip, (the situation I referred to in my post), all the burden would fall on them? How do you enforce their need to prove without taking on a burden of some sort? If they simply don't work on your car, the burden is on you to convince or compel them to do the work. You have to do something, like take them to court, to prove that you're entitled to service. And if you go to small claims, their mechanic is likely to be more credible than someone who isn't a mechanic and able to offer pretty convincing evidence if he/she can report damage that wouldn't happen under normal conditions. And the purchase contract may well specify that modifications alone, not consequent damage, is sufficient to void the warranty. I'd be pretty surprised if that weren't the case. Lawyers write these things and are pretty good at anticipating issues that they want to indemnify themselves against. And then, if something happens as a result of a mod, they're actually in the right. They didn't warranty a modified car, they warrantied the car as sold.
I'm not saying that this is the secenario that would routinely happen. It may never happen. But the notion that if it did, they would shoulder all the burden is questionable. People put chips in all the time and I don't think too many instances as I've described actually happen. But that doesn't mean that if they do, the owner can magically compel the dealer to fix the problem without assuming any burden or responsibility. And again, in such a situation, it actually would be the owner's fault, not the dealer's.
Hey guys,
Will try to check in on this forum from time to time to answer questions as they come up! We're all excited about the new G70 platform. :)
In terms of the JB4 what it offers that no other tuning system currently offers for the platform is CANbus integration. Meaning the JB4 is able to read and see every piece of information the ECU has. That gives us the ability to add in some unique features. Just a few off the top of my head:
1) User adjustable boost by gear to lower boost in lower gears for increased traction.
2) The tuning is able to take in and utilize much more information for its tuning integration including pedal position, engine temperature, throttle position, performance mode, gear, intake temperature, etc, etc.
3) More advanced safety systems with the JB4 monitoring AFR, fuel trims, knock, full time in the background, and reverting to a safety map if something looks out of spec for the map.
4) Full datalogging and diagnostics to your phone. See video below.
5) The JB4 has a lot of extra inputs/outputs allowing us to add things like direct fuel control, water meth integration, and more, as we further explore higher power levels with the platform.
In terms of the warranty stuff we always advise customers that if you break something by running it at higher than factory power levels YOU should pay for it. But that said with the JB4 in place we expect a very high level of reliability with the platform, and the JB4 system itself is diagnostically invisible and installs/removes in minutes. Since it has CANbus it's able to clear all codes and freeze frame data out of the ECU when needed.
According to the law, the burden of proof is on the manufacturer to prove the damage was caused by an aftermarket device. It is known as the Magnuson-Moss Warranty Act. Magnuson–Moss Warranty Act - Wikipedia
HOWEVER: (speaking as someone who has been on both sides of the issue, as a customer and as a dealership/corporate representative)
The dealership is not the manufacturer, the dealership will have a dealership employed warranty specialist. This persons job is to determine whether or not the manufacturer will reimburse the dealership for proposed warranty claims, if they feel there may be an issue getting paid back they can and will deny the warranty claim.
At that point it is up to the customer escalate to the manufacturers warranty department for review, sometimes the dealerships will do this for you, but in my experience that typically leads to the manufacturers area rep siding with the dealership, it is always better for the customer to make the contact and claim themselves.
If the manufacturer's rep decides that the claim has extenuating circumstances, they can deny it, and usually will, at that point the customer's first action according to 99% of car maker warranties: is arbitration, where in the manufacturer would need to provide proof that an aftermarket device caused the issue, so yes the burden of proof is on the manufacturer at this point. If the customer loses arbitration they can sue in civil court.
There are several factors that come into play, first, if the customer loses the arbitration, they are legally bound to pay the legal fees and arbitration fees incurred by the manufacturer, same if they lose the lawsuit.
The average cost to arbitrate a claim of this nature will likely outweigh the cost of the repair if not the cost of the vehicle, a lawsuit would be 2-3 times the cost of the vehicle. As such most people won't take it to the box, therefore the burden is now on the customer, because a manufacturer can legally decline a warranty claim and leave it to the customer to seek legal action to sort it out, and typically they don't because it is cost prohibitive for most people.
Now taking it from a customer perspective, I did take Chrysler to the box and sue them for a warranty issue, my lawsuit actually resulted in a full recall for 2005-2008 Chrysler 300 5.7L and 6.1L, and Dodge Magnum/Charger 5.7L and 6.1L vehicles. it cost me $29,000 in attorney fess which Chrysler had to pay, plus repair of my vehicle which amounted to $38,000. I had significant proof of a defect in the design of the motor, it was not modified, and it did not have any tune or other aftermarket items directly related to the fail.
In the case of the Stingers, the very first thing the dealer will look at is the spark plugs, if they have been changed to colder plugs, you bet your ass they will know the car was tuned, because it is all over the forums about what is needed for these piggy back tunes.. you can also bet your ass they will look at the forums and try to find any and all threads by the customer to see if there is any pattern of using aftermarket devices.
The JB4 is a fully programmable tuning system. We can set it for whatever power profile we want and with the extra inputs and CANbus makes the RC look like a toy. :) We provide free firmware updates with new maps, features, and performance levels as we test and develop them.
That said different strokes for different folks. Just remember our customers post ACTUAL dyno charts and detailed tuning data logs to go with them while many other companies just post theoretical numbers with little to support them.
Status
