ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
Cleaned out trunk (again) today, and looked under the false floor to where the Spare Tire and Battery are located. Something puzzles me.
The PLUS (+) side of the battery has two cables going to it. The smaller of the two is connected directly to the positive post, but the larger of the two is connected to a small box that sits next to the positive post. (this box also had fuses, and other things in it). I don't understand why it has two plus connections, and also how the two connections are connected to each other.
Wallymn changed to an aftermarket battery recently and would know how and why these two Plus connuctions work. WALLYMN, ARE YOU READING THIS? Also Wallymn, does your new battery have a vent tube like the OEM?
Also noticed that the Negative (-) cable connects to the bottom of the trunk. No Negative cables going through the car like the Positive.
Not even counting the cost of an OEM battery, just needing a battery in a hurry will be a problem if batteries can only be bought from a Hyundai dealer.
