ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
I know this is an old subject, however I decided to see what other cars if any, use this battery. I went into the Interstate Battery website, and found that the only battery listed for the Genesis was their MTP-H8. OK, I then when and checked other cars, and found their MTP-93. Looks the same, so I checked the specs.
MTP-H8 (priced between $192.95 and $225.95)
720 CCA (Cold Cranking Amps)
900 Amps
900 Cranking Amps
Weight 53.6 lbs
Width 6.80 inches
Length 13.94 inches
Height 7.48 inches
MTP-93 (priced between $136.95 and $163.95)
850 CCA (Cold Cranking Amps)
1000 Amps
1000 Cranking Amps
Weight 43 lbs
Width 6.88 inches
Length 14.38 inches
Height 6.88 inches
Don't know if there is any difference in the method of holding the battery down to the floor of the trunk, and also, don't know about venting the battery, although they should have a vent as they both are designed for the trunk of a car.
(Just knew you all would love to store this information in the "little gray matter" in your head) <grin>
900 Amps
900 Cranking Amps
Weight 53.6 lbs
Width 6.80 inches
Length 13.94 inches
Height 7.48 inches
1000 Amps
1000 Cranking Amps
Weight 43 lbs
Width 6.88 inches
Length 14.38 inches
Height 6.88 inches
