The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
See that's my point, people like you are what we need ,you have the knowledge of the inner workings of a build. I know you can put a sleeper kit on a 5.0 ! Turbos underneath the car instead of the top. I wish i had your knowledge, resources and expertise. I know just enough to be dangerous, you known enough to make dreams come true, there's your excitement, there a sleeper build in your head. Please picture this twin turbos underneath, front mounted intercooler, someone has to make injectors, I'm stuck on the piping. We don't have to run 20 psi at first just 5 to 8 psi we control the the with heat turbo blankets . Just come up with the piping, we can Frankenstein a kit. To me that's why I got the tune in case someone like you came around I'd have a better chance of not blowing my motor. I would love to talk to you, if you can't figure it out I know you know someone who could. God bless you or and thank you for responding.
Ok so I'm kinda new to all this performance stuff. So carguy75, I see you have a Sprint Booster V3. Can you tell a difference in exhaust volume? If so is there a way to turn the tune on and off or even adjust it for road trips and whatnot?![]()
Sprint booster just changes the throttle threshold. This means that you will have more throttle response with less pedal depression. There is no change to your horsepower, exhaust, 0-60 etc.
No offense, but have you even have a Sprint Booster? If not, how in the heck do you even know what results it does or not produce?
I own the device and have not really tested the unit enough to say for any certainty what it does or not as a fact.
I perceive that my car accelerates quicker with the Sprint Booster, but I have not really tested the outcome properly to actually say for a fact that my car accelerates quicker.
However, I understand that you believe that the sprint Booster does not do anything for the engine, but you are stating your opinion as a fact when if fact you never even purchased the item or used it I bet, let alone tested it to make such exact statements about the product.
I'm going to agree to disagree, I understand that the basis of what you are saying is true, if I'm going to run big boost, I would need a dyno tune, what I need in my opinion is a way for more fuel and 8 psi of boost. I feel like people want to kill everything in stead of shooting everything down let's find a solution. But ,Never a solution just a roadblock that's the reason why nobody makes anything for our cars. Look at pass post it's always what we can't do never what we can. Just my two cents, I hope I haven't offended anyone , I just want more power. And how does a community get this way? Nothing worthwhile is easy or simple together we are strong divided we are week.
Hello Carguy. To clarify, the sprintbooster is a voltage regulator device. It will amplify the voltage it receives from pedal depression, and therefore advance the throttle response in respect to pedal depression. Thereby, decreasing the amount of pedal travel required to attain a higher throttle. Hence, if your stock pedal depression at 75% gives you 75% throttle response, with the sprintbooster, it will now give you 100% throttle response. That's the entire purpose of this device. Factually, it has no other effect on the vehicle except for decreasing the distance required of the pedal to attain a higher level of throttle. That being said, if it makes your car more fun to drive, then that's great. I personally have nothing against SBs.
