IPod Controls
Flyinnb
Does anyone know of a way using the built in IPod controls to shuffle songs? I can only get the system to play songs in order.
You have to set shuffle mode on your iPod before you connect it. Then just hit the up/down arrows on the steering wheel to shuffle to the next/previous song.
I would like to see this feature added to an update on the system. Not sure how to go about recommending that since I don't have access to the Hyundai Think Tank because I live in Canada.
You have to set shuffle mode on your iPod before you connect it. Then just hit the up/down arrows to shuffle to the next previous song.
I have shuffle set on my Ipod, but I'm not sure what you mean about hitting the up/down arrows to use the shuffle feature through the DIS. When I hit the up/down arrows it just goes to the next song on the album I'm playing or the previous song. What am I missing?
Sorry I should have clarified (I'll edit my original post). If you press the up/down arrows on the steering wheel, it will shuffle forward or back on whatever playlist you are currently on.
I leave my ipod on "Songs" and just shuffle through all 800+ songs on my ipod.
I try again, I have a 60G Ipod and for some reason it does not want to shuffle when connected to the system
Ya maybe its the iPod you because my 8Gig Nano works fine.
Re: IPod Problem
Hello
I just rec'd my cord to use my Nano Ipod. I have discovered that when I play the Ipod the right speakers do not have sound. I tested the Ipod and with head phones directly from ipod it plays in stereo but not when hooked up to the car.
Controls seem to work and can skip songs etc I have tried changing settings but to no avail. Does anyone have any ideas what I am doing wrong or do I have to live with it????
Re: IPod Problem
Hello
Assuming that your other sources play on all speakers, it is probably the cord, or cord is not attached properly at both ends, or connectors are broken (on the cord or where the cord plugs in). Take it back to the dealer and have them try a new cord.
Hmmm tried second cord and same results. Only lift speakers have sound. I am using NANO ...could it be a setting on Ipod that is messed up?????
Went to dealer for first oil change ....they checked Ipod and found that the that the unit in center council was bad. New ordered should get new one in 2-3 days . Will let you know how it turns out
Re: IPod Problem
Dealer replaced the Ipod unit in the center console. The cord/ipod now works perfectly.
NO CHARGE. They also upgraded airbags...what that entailed I don't know but that too was free and it only took 15-20 minutes total.
