Passenger and rear door won't unlock
rickcioppa
My passenger and rear doors will not unlock with remote, handle or drivers control. They will lock with all three. Anybody have this problem?
You should touch your unlock button at the key fob twice, with driver door handle you need to touch twice too but once on the passenger side. Check the switch for lock/unlock doors too. Better read your manual from chapter 3-4 thru 3-14.
yes, I understand that. None of those options work to unlock the doors. and the manual was no help, Thanks
I think there is a setting for it in the dash board interface. Not home otherwise I would check for you.
Yes there is and there are pages and pages in the manual regarding various conditions and also how to reset them. Might be something to look into.
Jesus, you think the guy wouldn't know this? hahaha
I have encountered this issue. weirdly after a couple weeks, I think i accidentally fixed it. my actually steps to fixing it are kind of foggy but it involved either
1. (Un)Locking the door with the key fob while sitting in the car
2. Then manually (un)locking the rear driver side door with my hand from the inside.
I don't know which exact combination it was but i did this one day and it began working again.
Wow! Great reply! Thanks
I had this issue the dealership replaced something under warranty
Would you please be a little bit more specific as to what they did.
Thanks
I had an issue of all doors locks not working except the driver side when I bought mine used. Battery disconnect for about an hour reset everything and saved me a trip to the dealer.
my car door and truck will not open but it will lock? is there any specific buttons or settings?
sounds like a door lock actuator issue.
Most likely not a need to replace a part. Try the fuse reset option first. It's a setting that got changed. It's really rare for all actuators to go out at the exact same time.
Had the very same issue, I reset the connector as per the video and problem solved!
Thx so much Hisenberg :)
