Underside of G70
KBH
Are there photos of the underside of the G70 - both for the i4 and v6 powertrains?
Thanks.
Aren't you getting a bit personal? Veeery private info :eek:
I just took some underside pics of my new G70. I apologize for the fact that everything is covered in sand - it's typical February here in New Hampshire. (Maybe a bad way to introduce myself with this first post.)
I was pleased to see a true dual exhaust system, similar to my 335xi. However, I was a bit surprised and disappointed to find that it all appears to be steel, rather than stainless steel (according to my magnet). I understand some stainless can be magnetic. Just hope it lasts.
The rear suspension/sub-frame looks very familiar (sorry, no pic of that). I was intrigued by the dual lower front control arms. I also found what appears to be a vibration damper (?) of some sort bolted to the side of the front strut housings (shown in one of the photos). I haven't seen anything like this before.
After driving a few different BMW 3 series models for the last 12 years, and after reading all the G70 reviews and road tests, I thought I'd give it a try. Especially after being sorely disappointed with a number of aspects of my 2014 F30 335xi with M Sport package (notable a chassis apparently made from taffy, weak dampers and lots of interior squeaks and creaks). Still, I'm still getting used to driving something else, but enjoying it very much so far.
Dave
18018180191802018021
Sorry - meant to say that this is a 3.3T Design model, with about 1k miles on it so far (which makes the sand and salt all the harder to see - can't wait for Spring).
Dave
Now we just need aftermarket options for the downpipes, aside from JunB.L's set. Even seeing just part of it, it looks like there is room for improvement - even if you kept 2 sets of cats (although high-flow would be preferable).
Thanks for posting pics!
interesting pics! i wonder if the LCA set up and vibration damper is uniform across 2.0t and 3.3t trims. i've seen a vibration damper on ford ST trims. i believe it was for reducing NVH from aggressive brakes.
Has anyone undercoated their G70? Is it even worth it?
Lap 3 has downpipes with HFC option to reduce smell but will still cause CEL.
Yeah I've seen their downpipes. Wasn't aware that it would still cause a CEL even with the HFC?
