Buying matching rims to make V8 wheels non-staggered
genesis333
I ran through my first set of rear wheels at 20,000 miles. Since v8 19 inch wheels are staggered I'm unable to rotate them. Coincidentally, I found a used set of rear OEM rims and started thinking about replacing the front ones to make them match. Has anyone done this before? I read that ABS is only affected if the rim size is different, which should affect my case.
I don't think an extra half an inch will rub unless you run 275 front. 265 or less should work, but that kind of defeats the purpose of 19x9.
I feel that you would come out better by buying a pair of front wheels that can be installed on the rear axle and then use wheel spacers to push the rear wheels out to the fenders like the wider OEM wheels if you want to really go with a uniform wheel set without messing up the rear tract too much. Just my ideal.
The 5.0 staggered are the same size and offset as the sport staggered and you cannot put the fronts on the rear, the fronts have a different offset and back spacing and 245mm wide tires will rub.
If you reduce to 225 then they will work, but the offset is wrong so the wheels will appear to be tucked in too far and will look off compared to the front.
The only way to do this is to get the OEM 18” wheels and tires sizes as they have the correct backspacing and offsets to fit properly at all 4 corners.
Most tire shops will not put on spacers and for sure the warranty will be affected if anything in the rear breaks, the spacers will be blamed.
Spacers are not a good idea imo, unless they are hub centric with their own set of lugs.
And BTW the oem tires suck, 20k is about right for the soft rubber they are made of, your better option IMO is to get a better set of tires with a decent warranty. I’ve have this staggered setup on my last 3 cars exact same size wheels and tire, the oem tires on all 3 were done by 20k. My replacements last 50k easy, and I don’t rotate, never have.
Agreed, most popular chain tire shops will not sell nor install wheel spacers. However, many aftermarket wheel shops will sell and install wheel spacers. I personally do not trust wheel spacers due to being an extra part that can fail on the axle over time, however many owners use them obtain a flushed wheel appearance or increased traction so a good set may be fine to use.
I personally would not use spacers on my Genesis since I like the staggered setup, but they seem like a better ideal that putting the wider rear wheel on the front axle..
I want to put 20 inch on my 2015 5.0 but the front caliper is so big that I might have to use wheel spacer. I don't want to use them so if anyone has any option for rims to fit let me know. with pictures if possible. And I do not want the staggered look.
Do you know about installing aftermarket 18" wheels that run 245mm all around (245/45/18). I'm trying to understand if this would fit on my 5.0
Yes, they'll fit.
I've posted this in several threads out here and it reflects the stock wheel sizing for both the 3.8 and 5.0:
Hyundai Genesis 2015 - Wheel & Tire Sizes, PCD, Offset and Rims specs
Hyundai Genesis 2016 - Wheel & Tire Sizes, PCD, Offset and Rims specs
I found 2 bent rims on my 15 Whitey, I thought it was tires due to the simple fact the dealer and a tire place both checked them out when I first got the car and they said they were good. WTF! if you want something done right do it yourself!!
Car is very smooth now! Go figure!
Yep Kraig, go figure. Nothing surprises me anymore. Tires are the usual culprits so they rule them out and say all is good, rather than go the extra step and actually help someone. So the old proverb continues to hold true. Glad you're rolling smoothly now! (y)
