rickcioppa
- Dec 19, 2011
My passenger and rear doors will not unlock with remote, handle or drivers control. They will lock with all three. Anybody have this problem?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
You should touch your unlock button at the key fob twice, with driver door handle you need to touch twice too but once on the passenger side. Check the switch for lock/unlock doors too. Better read your manual from chapter 3-4 thru 3-14.
Wow! Great reply! ThanksYou should touch your unlock button at the key fob twice, with driver door handle you need to touch twice too but once on the passenger side. Check the switch for lock/unlock doors too. Better read your manual from chapter 3-4 thru 3-14.
I had this issue the dealership replaced something under warranty
This worked for me! Thank youDealer recommended to reset connector in the fuse box. It took about 1 minute.
Here is video link showing how to do this: Genesis Unlock Doors Fix
Most likely not a need to replace a part. Try the fuse reset option first. It's a setting that got changed. It's really rare for all actuators to go out at the exact same time.sounds like a door lock actuator issue.
Fuse reset worked great, problem fixed... thanksDealer recommended to reset connector in the fuse box. It took about 1 minute.
This did the trick for me too as I had the same issue. Thank you.Dealer recommended to reset connector in the fuse box. It took about 1 minute.
