Take any N/A car.
So, you're saying if a mechanically stock car with an ecu tune, raced a car with full intake, exhaust, lightweight wheels, summer tires and a sprint booster, they'd be tied or even close???
You're talking Dyno numbers, I'm talking real world acceleration. N/A cars need to be mechanically tuned/modded to see real gains. You can't "program" the intake and exhaust to be more efficient at higher rpm. You can't tune fire less drivetrain loss. One of the most effective parts of an N/A tune is remapping the throttle, and that can be simulated with the sprint booster. A good Dyno tune is a gift from God on a well modded, well maintained car. A tune on a stock car, you see minimal gains and a slight bump in driveability.
If these we're boosted car, you'd be absolutely right. They gain power from tunes simply by upping the boost, the rest of perameters are changed just to make sure the car handles the increased boost.
Well I think you don't understand the true fundamentals of how an engine makes power? First off you can't just slap a turbo car on the dyno and "change parameters" so the car will handle more boost? Lol Plus the only reason what you are talking about is even possible is because the manufacturer has it de-tuned..
See all cars are tuned by the factory to give the best performance they can while maintaining drive ability, comfort, mpg, but MAINLY, things like passing emissions, maintaining the life of the smog system, and keeping reliability up above all else. Doesn't matter what type of engine the car has, from the factory they are very conservative..The smallest power gain you'd see on any stock vehicle is 15/20 to the ground.. , ,
The only way an engine makes power is by burning fuel and air.. you wanna go faster? You burn more of that stuff or you take things off to make the power/weight greater..
You like many others greatly overestimate the power you gain from putting on a CAI and exhaust.. Take what manufacturers say and throw it out the window.. at most a intake will net you 2-5% power, exhausts on most cars are simply a sound change.. unless their are tons of cats and resonators or restrictions the most you'll gain is
2-3%. So say generously you put an intake and catback on a 3.8 gen you'll gain 16-17 hp..estimated.. That's pretty much the same to me?
You're only other mod deals with tweaking the drive by wire response. The car isn't faster? You just have to move the peddle waaaay less to get full throttle conditions. Now a real tune is going to set that response as well, it's going to change all the tq management. Shift points, rpms, harder faster shifting, they are going to lean your A/F out to make peak power while still being safe (which will melt and destroy cats) and they are going to keep throwing timing at it till it detonated.. But as I mentioned above via your comment on turbo cars, you can only increase the fuel so much before you run out of injector or pump etc..
Yes parasitic drag from unsprung weight is a big performance drop.. and reducing weight is the fastest and cheapest (via stripping stuff out) way to increase power. But good lightweight
rims and summer tires are not at all cheap to say the least?? For an E-bay set of cast aluminum crap you're talking $1k before tires and they MIGHT be lighter than factory alloys. If you are talking about
rims that are going to be 12-15 lbs lighter then bump that to $2500/3000 for the
rims alone..
If the scenario happened that you mentioned above yes the tuned car would bear the intake, exhaust, throttle chip setup. BUT, if that bolt on car had the
rims and tire setup it would prob win then.
Again it's about the same.. but if you tune the bolt on car it's a no brainer.
