rtrofimovich
- Aug 21, 2015
Hi all. Was thinking about doing a fluid change on the Genesis (ZF 8 Speed). Car just hit 100K (100,087 to be exact) and every now and then I've been getting some rough shifts the past couple months, usually into 3rd or into 5th. I've read up on ATF changes in trannys that haven't had regular fluid changes, and there are some real horror stories of transmissions failing after a fluid change. This is apparently caused by the strong detergents in new ATF breaking loose debris in the trans and that debris clogging valve bodies, passages, etc. I don't believe my trans has ever had a fluid change (I purchased at 31,000 - never had any issues so didn't think too much about it). I'm wondering if anyone has been in a similar scenario with their ZF 8 speed where they had their only ATF drain/fill at 100,000 miles with no previous service. What were the results after? Any issues following new fluid? Really would appreciate any responses! Thanks!
