yolonge
- Apr 3, 2019
- Location
- Cockeysville, MD
Purchased at 33k miles as second owner; due to the timing of first owner purchase, I still have 11 months left on the warranty so not to concerned now. First owner did oil change every 5-6k miles and car was well maintained.
Many noted problems are common and discussed frequently here. Will bring the car to dealer soon to address the issue.
So far, did oil change (about $100), replaced breaks (about $650), and replaced both turn signal bulbs ($5). Unfortunately, I cracked windshield on the highway (not car's fault) so that will add about $500 more.
1. Panoramic sunroof squeaking and popping
First half squeaks from time to time. Second glass (non-removable) can make popping sound when car was parked under hot sun and when body flexes for couple minutes.
2. Hood vibration at highway speed
This is probably glue issue. I believe some people have resolved this issue on their own.
3. Flutter at around 30mph when car is cold
Very common issue. Drive shaft assembly/propeller?
4. When driving around 65mph (noticeable with cruise control with no acceleration), little high frequently noise
Could be transmission?
5. Dual climate control issue - When car is parked, driver's side is cold and from time to time coldness and strength of the air are inconsistent over driver vs. passenger side. AC works when car is in motion.
6. When car initially starts, it makes louder starting sound for 5 second or so
7. Beige leather seat is not too durable and peels a bit (do not wear jean!)
8. Quad exhaust blackening - this is probably caused by GDI
9. Weak trunk opening - sometimes it may not fully open by its own
I will add more if I can think more.
