New 3.8 L owner looking to start modding
Danimalz
New Genesis owner here! I plan on start building out my 3.8 (not too much, just a little here and there). The 2 modifications that I plan on doing so far are adding a K & N air filter and then a new exhaust ( I was thinking magnaflow). What have you guys done in terms of starting to mod 3.8's and what are do's and don'ts.
(also what type of exhaust systems are using if you are using after market)
Thanks!
Thanks!
As far as exhaust
The difference between the two is the 2ndary cats and the tips and about 400 dollars lol. The 15059 was made for the r spec which had the bumper exhaust. Literally everything else is the same throughout. Same mufflers/x pipe/ and pipe dimensions
The one for the 5.0 still has 2nd cats aka 15059View attachment 22187
However the 4.6 aka 16497 comes with them deleted. And has quad tips
Both options will fit 3.8 just fine
I'm selling storm lowering springs if you're interested in a nice lowered look/comfortable ride. Here is a few pictures of the ride height on the springs and OEM shocks/struts.
Any other ideas look at my sig *edit*
If you're on a phone you cant see it but here is a mod list of my 3.8l
2013 3.8L v6 Premium Pkg 91700mi
Stock Color Caspian Black Pearl~~Black on Black Interior
ZTA Hypershift W/ Blueberry Juice + High Gloss Autoflex **Peel-able Liquid Wrap**
Injen Short Ram Intake W/ Custom Heat Shield
Illuminated Genesis Door Sills
De-badge/CF KDM Trunk Emblem Replacement
Brembo Swap *Wizard Red* W/ Slotted/Drilled Rotors + Steel lines {{Thanks for the trade Xiaphin!}}
Magnaflow Cat Back 16497 W/ Quad Burnt Blue Staggered/Slanted
Wheels - Rohana RC10 Matte Graphite w/ Gloss Black Lip F: 20x9 +25 R: 20x10 +40
Tires - Michelin PS4S Current: F-235/35/r20 R-275/30/r20 Future: F-265/35/r20 R-305/30/r20
Storm Springs(Custom BR Coil DS series 8k F-Swift Springs/R-10k spring rate)
Uniq Performance Rigid Collars
Full Ultra Racing Stability Bar Kit
Thing handles like a Beast through mountain switchbacks.
Have plans to eventually swap in a 5.0 after i get hopefully at least 200k out of my 3.8 or possible 3.8T kit in the future now that ecu is tunable and they just released 9ne for the BK platform.
any idea on pricing of those?
Well they dont have one for our vehicle specifically so no.. but a starting point for a retrofit would be 4k for the BK2 3.8T and I'm sure a bit more money and a lot of time to actually retrofit the kit
Thats crazy I was thinking of cutting out muffleds and adding in 18' or so glasspacks. Much easier on the budget
I'm pretty excited I'm getting a ported TB and having entire intake manifold upper and lower ported and polished. I will then be tuned for 91 pump(cali things) aaand be pretty much at the limit as far drawing power from this 3.8 motor.. I do have plans to try ands get some dyno time in before hand so that the numbers can be compared
Interested in those numbers for sure
Keep posted
