CanukV6
The V6 does not have a limited slip differential, but that's not necessarily a bad thing, even though one would think that having both wheels exert torque when in winter sounds like a good thing. It is not - especially on low traction surfaces.
If you have a normal differential, when one wheel slips it starts spinning and all the engine speed goes to that wheel and the other wheel just rolls on. This is good because it tends to keep the rear moving in the same direction as before the loss of the spinning wheel traction. Since the free wheel rubber is still rolling in contact with the surface the direction of rotation keeps the rear from moving sideways. It keeps the car from spinning since one wheel has traction, and one wheel has power.
With a LSD, the coupling of the two wheels together means that when one starts spinning it draws the other side into the same spin, and you end up with a good chance the rear is NOT going to keep in line (especially in a turn or even on the crown of the road surface). Both wheels have power, but neither have traction, and you end up sliding around without control.
The best thing to have in winter is not a LSD, its winter tires designed to provide traction in cold, snow and ice. It doesn't matter how many wheels have power if none of them have traction - look at all the SUVs in ditches every winter.
While I totally agree with your statement about Winter tires being the best aid to traction in snow and ice, I do take issue with your comments about LSD's. An LSD will allow more power to be delivered to the driving wheel with the most grip. If one wheel starts spinning then torque is reduced to that wheel and greater torque is applied to the remaining driven wheel. An open (normal) differential provides the same torque to both wheels regardless of their individual grip.
