15 Hyundai Genesis sedan 3.8(G80) no crank/no start
JbabyMia
I initially was dealing with a dead car battery, after trying to jump start the vehicle the car stopped trying to crank all together.
I have put in a new car battery and new batteries in both keys, the car does nothing. The light that I’m getting is the car with the key through it as if the key is not registering and the system is locked.. I have tried pushing the key fob on the start and still nothing... HELP PLEASE
It's been many years since I've been under the hood; got to be old and lazy but verify you can still turn on the lights. This will indicate there is voltage available. Other than that, all I can offer is call the dealer. Sorry.
If you have lights do you hear anything when you try to start, e.g. any clicks, or other noises? If not check fuses and if you have, or can borrow one, use a code reader to check for any codes stored in the OBD.
Also, I do not know if the '15 has it, but later Genesis models have a switch in the dashboard fuse panel that has to be "on" for a lot of things to work.
It probably needs a starter. Mine did. See my post about this problem.
