2015 Tau GDi fit n a 2012?
Donovan_787
I have a 2012 RSpec Genesis which has the GDi V8. I was told that this V8 engine usually fail at around 75,000-100,000 miles. Is it possible to swap in the Tau GDi V8 from a 2016 Genesis?
  • Wow
Reactions: MG8
You were told wrong. Keep oil changed, use OEM oil filters. There are many of those engines lasting past 200,000 miles. I know one friend of mine that has a 2012 R-Spec that is over 225,000 miles and still going strong.
  • Like
Reactions: MG8
some rspecs from that year are known to burn oil but not just fail at 100k, keep it full of oil and it'll be fine for a long time
  • Like
Reactions: MG8
nope, these motors are bullet proof.
I hope you are right because I read about the oil burning issue in a Jalopnik article. How many people do you know of that have over 200,000 miles on their 2012 Genesis Rspec? I use Mobil -1 fill synthetic and K&N oil filter
dont believe everything you read. this does not happen to every Genesis 5.0 Rspec if it did it would of been a recall.
My car burns a lot of oil. I need to confirm how much after 1000 miles.
that sucks, bring it in the dealer and have them replace the rings.
or just top it off , how many miles do you have?
You should only use Hyundai oil filters and try using 5w30 synthetic oil unless temps are below zero.
or even put a 10w30
Just keep the oil full and you'll be good.
I made the mistake of thinking I was good to go and not checking my oil. My r spec was one of the rare affected engines.
A 2015 GDi is real similar in almost all part numbers. When I changed out my engine, I just went with another 12-14 engine, as the 15 didnt have enough exactly the same for me to gamble on.
My 2012 RSpec 5.0 has 140,000 miles and still running like the day I got it 6yrs ago. It does burn oil, but I noticed that a couple years after I got it.
  • Like
Reactions: MG8
“Same “
