EdRomo
- Feb 1, 2020
The other day my key fob battery needed to be replaced, so changed it out and then the car wouldn't start. (Click, click, click...) I thought it was the key fob needing to be reprogrammed but after some research I found out that the battery needed to be replaced. The local dealership is about 20 miles away, so not convenient. So I went to AutoZone and picked up a DuraLast H9 amg with 1000 CCA for about $200. Could have went with a cheaper battery but I had noticed most of the complaints out there came from the people buying the cheaper ones under 900 CCA that cost about $140. You'll need a 10mm socket and the bolt at the base is about a 1/2 inch. 4 in all. Installation was a breeze. I did notice that the spare was flat so I was able to inflate to 60psi. After installing the battery the car started right up.
