Gas type?
Jthecub
I know it sounds silly but I just bought a 2013 R Spec sedan. It didn’t come with an owners manual and yes I tried searching for one online and couldn’t find one. Should I be using 91 octane? The gas cap doesn’t say anything. I have been using 87 but don’t want fo reduce performance or wear out my engine if I am using the wrong fuel.
It will run on 87, but HP will drop to 420hp. 429hp is based on 91. If you go with a performance tune you should keep to 91. I just bought a '13 R Spec as well, I figure to just keep putting in 91 despite the extra cost. Going for a performance tune later in the summer so figure I'd get used to the extra cost early. :)
BTW, pretty sure the manual is around somewhere. I got one with the car but also found an electronic one online.
Thank you! I am going to have to look into that tune as well!
Years ago, I read the using Premium will only give you a 3 to 4 HP boost, with the 5.0L....Hardly worth it.
The real question is will it be healthier for the engine in the long run
