brp
- Jun 20, 2020
- Genesis G80 Ultimate
With help from others on this forum site I attempted and successfully installed a Jbl basspro hub subwoofer in my 2016 genesis sedan ultimate. I had to modify the spare tire tool tray as you can see in the photos, but if I decide to remove sub I can glue the tray back together and reuse as normal. The car is very insulated so it doesn’t provide ground shaking bass, but fills in the low end much nicer now. It shakes the rear view mirror and had to cushion backside of license plate, but sounds clean with punch. If anybody else attempts to try this you will have to maintain the height of tool tray to support the trunk mat and keep it level so measure twice and cut once. I didn’t post pick but the tool tray sits nicely on top of sub and the trunk mat sits as if nothing was changed. Also you will need a 10mm 1.25 threaded rod ,washer, and nut for hold down extension .
