The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I disagree about not changing the original transmission filter.When replacing my tranny fluid + pan, my indy was able to drain just under 7qts of fluid.
The filter is attached to the pan, so you have to replace the pan if you want to replace the filter. Having said that, I was told replacing the tranny filter is unnecessary. Check Post #19:
2016 Equus Ultimate
2016 Equus Ultimate
What part number is the pan?
3.8 with the 8-speed transmission.
I totally agree with you Carguy75. The dealer did my trans about 2 months ago. They did not replace the pan and filter assy? WTF When I paid for it I realized they did not do what I had asked them to do. Its whatever. That was at 34k , I will take it back at 44k and have them do it. I agree with you about the break- in material in the screen/filter being heavy with junk. Either way its $ well spent. Shifts nice and smoother now.I disagree about not changing the original transmission filter.
Transmission filters do become clogged over time and do reduce the flow rate of the transmission fluid pump that provide lubrication to the transmission. The original transmission filter is the most important to change for a long transmission life due to being full of fine break-in metals/clutch materials from when the transmission was new. However, a new replacement transmission filter/pan should be go for another 100k miles or more since most of the extra fine metals will be removed after the first filter change.
Who recommended that an original transmission filter should not be changed? Sound like they want you as a repeat customer in a few years.
OUt of curiousity, which one did you get?Depending on your vehicle’s production date, the part number is:
45280-4F001 or 45280-4F320
