Mine was 16 GB.Do you know what is the size of the stock SD card on the car?
Sounds like you need usb stick.Update attempt #1 with the downloaded version failed. The update button on the settings screen is grayed out even with the new SD card inserted. Anyone else run into this problem? I have a 2015 Ultimate running the original late 2014 version of the software.
My first update was like that. Mapnsoft sent me a sd card and USB stick.Update attempt #1 with the downloaded version failed. The update button on the settings screen is grayed out even with the new SD card inserted. Anyone else run into this problem? I have a 2015 Ultimate running the original late 2014 version of the software.
No I dont. I am not computer literate. I am sure there is someone on this forum who knows what is on there.Do you know what was on the USB stick?
First update to a 2015 ultimate the update button is grayed out and requires s usb stick. After that the update button is enabled. I haven't tried the new free download since I recently bought v14 which came with both the usb and the sd.
I would think you can copy the sd to a usb stick and try it. Insert both and see if the update button is enabled.
I had good luck both times I have updated my 15 Jog Dial.I updated using the SD card they sent in the mail a few weeks back and again today using the download.
The initial update had a problem where map would be blank if zoomed in more than .25 mile scale. The problem resolved with the downloaded version. I’m not sure what the version numbers of the two software files are. It appears that they fixed some bugs.
I used a 32gb SD card to download the update. The downloaded failed a few times last week but worked today. The downloader program may have been updated too.
I have a 2015 with touch only 8” Navi.
I just tossed together a quick video on how to get the updates from the Korean site until the English downloader is back online
Can't locate my 2016 3.8 Luxury on the windows version that I followed your link to.Here's the current updater client. They have the same client for both KR/EN. Web devs are just being lazy and dropped a popover on top of the download button. Update requires an SD card that is LESS than 32GB in formatted size, since the head unit update utility doesn't know what to do with bigger partitions.
Windows:
Mac:
